Начало выбивать ошибку р0171,едет вроде без изменений,обороты не скачут.В чем может быть проблема,подскажите где копать?
A code P0171 may mean that one or more of the following has happened: The MAF (Mass Air Flow) Sensor is dirty or faulty Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. There could be a vacuum leak downstream of the MAF sensor Possible cracked vacuum or PCV line/connection Faulty or stuck open PCV valve Failed or faulty oxygen sensor (bank 1, sensor 1) Sticking/plugged or failed fuel injector Low fuel pressure (possible plugged/dirty fuel filter!)
Read more at: https://www.obd-codes.com/p0171
Copyright OBD-Codes.com
Катаюсь на газу,можно ли исключить топливный фильтр?
Изменено пользователем Semma
