icechieff Опубликовано 3 августа, 2010 Опубликовано 3 августа, 2010 Model System ConnectorColour F1ReadingErasingFault Codes F2ActuatorTestF4 AdvanceAdjustment205 SI INJ/IGN Green YES YES YES205 GTI XU9JAZ INJ/IGN Green YES YES NO405 XU9< 93MY INJ/IGN Green YES YES NO405XU10J2> 93MY INJ/IGN Green YES YES YES405 Mi16XU10J4> 93MY INJ/IGN Green YES YES NO306 XR/XTXU7JP INJ/IGN Green YES YES YES306 S16XU10J4 INJ/IGN Green YES YES NO306 ABS Grey YES NO NO306 ClimateControl Brown YES NO NO605 INJ/IGN Green YES YES NO605 ElectronicSuspension Blue YES NO NO605 ABS Grey YES NO NO605 Air Bag White YES NO NO605 ClimateControl Brown YES NO NO CONNECTING THE TESTEREnsure that the slider switch is in position 1Connect the red and black clips respectively to the + and - battery terminals.Connect the black 2 pin socket to the diagnostic connector."F1" must be displayed in the top screen, if not, disconnect and repeat the procedure.Press on the Blue Button to scroll through the four functionsFUNCTION NUMBERSF1Autodiagnostic Tester - Reading/Erasing fault codes. F2 Actuator Test - enables operation of certain components controlled by the control Unit. F3 Mixture adjustment (not used in Australia) F4Ignition adjustment - enables timing adjustment on Magneti Marelli Engine Management Systems. When the desired function number is displayed confirm your choice by pressing the White Button. F1 - AUTODIAGNOSTIC TESTThis function allows the operator to read and erase the control unit memoryReading the memoryCarry out the connection procedure - Select "F1""C1" appears: - turn the ignition on within 7 seconds.Wait for "00" tobe displayed.Press the Green Button until the upper right dot of the top display has lit.The fault codes are displayed vertically, starting with the "12"indicating the start of test and finishing with "11" indicating the endof the test.Note:Once the Green Button has been pressed and released no other action isrequired on the TAD 4-99. Wait until the code "11" is displayed to indicate theend of sequence.If more than 4 fault codes are received by the tester, the centre point of the last display panel lights up to indicatethat there are more codes. To view these codes press on the Green Button.Erasing the memoryTo erase the control unit memory you must first read the memory and wait for code "11"(end of test sequence) to be displayed. Hold the red button down until "EF" is displayed. (3 seconds)"EF" will be displayed throughout the entire period of clearing. Once clearing is finished, the display indicates "00". - you must wait for "00" to be displayed before disconnection.Read the memory again. If clearing has been effective, the only codes to appear should be "12" and "11".After clearing the control unit memory it may need to be re-initialised.F2 ACTUATOR TESTThis function allows the operator to operate certain components controlled by the Control Unit.Actuator TestCarry out the connection procedure. Select "F2""C -" is displayed:- You have 7 seconds to ensure that the ignition is OFF."C1" is displayed:- You have 7 seconds to ensure that the ignition is ON."- -" is displayed:- after a few seconds the first actuator will operate and the actuator code will be displayed.To move to the next actuator depress the Green Button for 3 seconds.After a few seconds the next actuator will operate.To end the test turn off the ignition.Important:When operating the injectors through the actuator test, fuel is being sprayed into the inlet manifold. Do not perform this operation for any longer than 15 seconds.F4 IGNITION ADJUSTMENTThis allows the operator to carry out a timing adjustment on the Magneti Marelliengine managemant systems.Ignition adjustmentCarry out the connection procedure. Select "F4""C -" is displayed: you have 7 seconds to turn the ignition OFF."C1" is displayed: you have 7 seconds to turn the ignition ON.After a short period, "- -" should appear, then code "22"will be displayed.The system is now ready to accept an ignition adjustment.Press the Red Button, one of the following numbers should appear:(19, 11, 12, 13,14, 99)To adjust, depress either the Red Button (retard) or the Green Button (advance)until the required setting code is displayed.Note: Hold buttons down for at least 3 seconds.To memorise the required ignition setting code, depress the White Button and hold for 6 seconds. Without pressing any further buttons wait for code "11" to appear. This is the validation code from the ECU to the TAD 4-99.Note:It is important to wait until code "11" appears. If TAD 4-99is disconnected prior to this, the modification may not be memorised.Timing Codes19 - 0° retard (original factory setting)11 - 2° retard12 - 4° retard13 - 6° retard14 - 8° retard99 - 0° end of range (limit stop) FAULT CODES Fault codes for Magneti Marelli 8P injectionAll 306N3 Models except S16, 405 SRI MY93 onward.CodeDescription13Inlet air thermistor14Coolant thermistor15Fuel pump control21Throttle potentiometer22Idling regulation stepper motor control27Vehicle speed sensor31Mixture regulation auto-adaptation33Inlet manifold pressure sensor34Canister purge valve41Engine speed sensor42Injectors control45Coil 1 control function52Mixture regulation53Battery voltage54Ignition injection Control Unit57Coil 2 control Fault codes for Magneti Marelli FD Monopoint G5 and G6 injection205 SI, XU5 1.6 litre engineCodeDescription13Inlet air thermistor14Coolant thermistor21Throttle potentiometer22Idling regulation stepper motor control31Mixture regulation auto-adaptation33Inlet manifold pressure sensor41Engine speed sensor42Injectors control45Coil 1 control function52Mixture regulation53Battery voltage54Ignition injection Control Unit57Coil 2 controlFault codes for Bosch MP3.2 Injection306 S16, 405Mi16 MY93 onward. (2 litre engine)CodeDescription13Inlet air thermistor14Coolant thermistor15Fuel pump control21Throttle potentiometer22Idle regulation valve25ACAV solenoid valve31Mixture regulation auto-adaptation33Inlet manifold pressure sensor34Canister purge valve41Engine speed sensor44Knock detection51Oxygen sensor52Mixture regulation53Battery voltage54Control Unit65No. 1 Cylinder reference sensor71No. 1 injector control72No. 2 injector control73No. 3 injector control74No. 4 injector control Fault codes for Bosch Motronic 1.3 Injection205 GTI, 405, (except MY16) up to MY93. (1.9 litre engine) XU9J2, XU9JAZCodeDescriptionChecks13Inlet air thermistorCheck the relevant component and its wiring.14Coolant temp. sensor21Throttle switch (idle position)33Airflow sensor34Canister purge valve35Throttle switch (full load position)42Injectors15Fuel pump relayFuel pump controls31, 32Mixture regulationIntake air leak, exhaust leak51Check Lambda sensor52Try with new ECU53Battery voltageCheck charging system; connections22,54ECUTry with new ECU41Vehicle speed sensorCheck sensor and wiring Fault codes for Bosch Motronic 1.3 Injection 405 MY16 up to MY93. (1.9 litre engine) XU9J4CodeDescription13Inlet air thermistor14Coolant thermistor15Fuel pump relay21Throttle switch idle function22Idle regulation valve31Mixture regulation auto-adaptation32Mixture regulation auto-adaptation33Air flow sensor34Canister purge valve35Throttle switch full load function41Engine speed sensor42Injector control43Anti-knock function44Knock detector51Oxygen sensor52Mixture regulation53Battery voltage54Control Unit55Mixture adjustment potentiometer Fault codes for Bosch 2E Anty-Lock BrakesCodeDescription12Start of sequence15Safety relay control check16Stop lamp switch18Toothed wheels conformity33Rear LH wheel sensor34Front RH wheel sensor35Rear RH wheel sensor41Front LH wheel sensor42Front right wheel inlet/outlet solenoid44Front left wheel inlet/outlet solenoid 51Rear wheels inlet/outlet solenoid53Pump motor55control unit disconnected56Autodiagnostic line57Supply after safety relay -1
